546
Export Infragistics.Excel to PDF
I'm using Infragistics.Excel to create a WorkBook in my application.
Is there a way to use Infragistics.Documents to export this WorkBook (WorkSheet) directly to PDF without using MS XL?
Regards
  • 469350
    No, there's no way to do convert an Excel Workbook into a Pdf document. You would have to create the Pdf document separately, just as you did the Excel Workbook.
    If the Excel Workbook is coming from an UltraWinGrid, then you could export the grid to Excel, Pdf, and/or Word very easily using the exporter components in NetAdvantage, though. So, depending on what you want to do, it might be worthwhile for you to build a WinGrid that has the data you want and then you can export to any format very easily.
  • 546
    Dear IG team, could you please answer my question.
