20
Licence problems?
i got following errors when I tried to build:
------ Build started: Project: Hogia.TW.Controls.Windows, Configuration: Debug Any CPU ------
My Project\licenses.licx(1): error LC0004: Exception occurred creating type 'Infragistics.Win.Misc.UltraDropDownButton, Infragistics2.Win.Misc.v10.3, Version=10.3.20103.2056, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' System.ComponentModel.LicenseException: No license information found
------ Build started: Project: Hogia.TW.UserControls.Windows, Configuration: Debug Any CPU ------
ResGen : error RG0000: Could not load referenced assembly "U:\TWSystems\Clients\Current\HTMS Clients\Hogia.TW.Controls.Windows\bin\Debug\Hogia.TW.Controls.Windows.dll". Caught a FileNotFoundException saying "Det går inte att läsa in filen eller sammansättningen U:\TWSystems\Clients\Current\HTMS Clients\Hogia.TW.Controls.Windows\bin\Debug\Hogia.TW.Controls.Windows.dll eller ett av dess beroenden.Det går inte att hitta filen.".
------ Build started: Project: Hogia.TW.Forms.Windows, Configuration: Debug Any CPU ------
------ Build started: Project: Hogia.TW.GUI.Windows.HTComplete, Configuration: Debug Any CPU ------
C:\Windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.Common.targets(1360,9): warning MSB3245: Could not resolve this reference. Could not locate the assembly "Microsoft.ReportViewer.WinForms, Version=9.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a, processorArchitecture=MSIL". Check to make sure the assembly exists on disk. If this reference is required by your code, you may get compilation errors.
C:\Windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.Common.targets(1360,9): warning MSB3247: Found conflicts between different versions of the same dependent assembly.
ResGen : error RG0000: Could not load referenced assembly "U:\TWSystems\Clients\Current\HTMS Clients\Hogia.TW.Forms.Windows\bin\Debug\Hogia.TW.Forms.Windows.dll". Caught a FileNotFoundException saying "Det går inte att läsa in filen eller sammansättningen U:\TWSystems\Clients\Current\HTMS Clients\Hogia.TW.Forms.Windows\bin\Debug\Hogia.TW.Forms.Windows.dll eller ett av dess beroenden. Det går inte att hitta filen.".
========== Build: 0 succeeded, 4 failed, 5 up-to-date, 0 skipped ==========
Do anyone have a suggestion?
BR
Kenneth
  • 8607
    Hello Kenneth,
    Could you please try to delete all of the content from your licenses.licx file and rebuild?
    Elizabeth Albert
    Localization Engineer
