4028
UltraNumericEditor - MaskInput problems
I'm using an UltraNumericEditor to display a read-only percentage value. I want it to display negative values, and have at least 2 decimal places displayed at all times, and possibly four (if there are 4 decimal places).
So far, I have set the following properties
 FormatString: ##,##0.00##%
 MaskInput: -nn.nnnn
NumericType: Double
ReadOnly: True
I realise the MaskInput is only used during input, and as this is read only, may not be that relevant. But if the user clicks in this field, I want it to continue to display the decimal places.
For displaying only, these properties work fine. If the value is 34.112233, it will display 34.1122%. This is exactly what I want.
When the user clicks in the control, it is a different matter. I lose the decimal places - it goes to just 34. What should the MaskInput be in this situation? I have tried some of the standard MaskInputs, and they dont seem to do the trick either.
