I created a ultratree where each node is tag with a cutsom class. When the ultratree view's click event is handled I am not seeing where in the sender or e parameter where I can obtain the node assocoiated with the item clicked on, or a way to get the node's tag?
Any ideas on how to do this?
Please do not hesitate to write us if you have any further questions.
Regards
You can forget this question. The sender ActiveNode Property gives me the current node
