665
How to disable multi select in a UltraGrid
No doubt I'm probably missing something easy here but I would like to disable multi select in a UltraGrid i.e. You can't select multiple cells or rows etc.
In addition it would be good if you could switch off the ability to select cells or rows etc all together as long as you can still activate cells.
Paul
  • 71886
    Verified Answer
    Hello Paul,
    Could you please try setting the following:
    ultraGrid1.DisplayLayout.Override.SelectTypeCaell = Infragistics.Win.UltraWinGrid.SelectType.Single;
    ultraGrid1.DisplayLayout.Override.SelectTypeRow = Infragistics.Win.UltraWinGrid.SelectType.Single;
    As to your second question - please review the following code and see if it meets your requirements:
    ultraGrid1.DisplayLayout.Override.CellClickAction = Infragistics.Win.UltraWinGrid.CellClickAction.CellSelect;
    Please feel free to let me know if I misunderstood you or if you have any other questions.
