hi,
We used UltraWind Designer to create datagrid. In the grid there is a column allow users to edit the text.
We have problem when users type too fast all the text will be disappear then it comes back. Some how the text field not display quick enough at user type input in the field.
Can you someone help me with this problem?
John
Mike,
How do set spell check when it leaves edit Cell.
Example I have description columns on grid that allows users to edit. But I don't want spell check take place while they type. I want spell check trigger when it leaves the cell. I got it worked before but forgot.
Hi John,
There is no reason why typing fast should have any effect. Like I said, I'm a very fast typist and the grid has no problem whatsoever keeping up with me.
If there is some kind of delay, then my best guess is that something in your code is causing it.
What events of the grid are you handling? Try commenting them out temporarily to see if that solves the issue.
Another thing you might try is - set the Visual Studio IDE to break on all run-time Exceptions. Perhaps there are exceptions occurring as you type that are being caught and handled and these are what is causing the delay.
There is no dropdown list bind to the grid. Grid just bind to datasource. In the grid I have few edit columns. All it does it allow users to select a row to edit some column and click submit.
The problem occurs when users type fast to edit column, there will be a delay for the text to display. This becomes very big problem to our users. We may need to drop this tool and use something else.
I don't see anything here which attaches a dropdown list (ValueList) to this column. But if you are using a dropdown list on the column, then you should not also set CellMultiLine to true.
Here is example of the edit column I have problem.
Below are property I set for this column
Infragistics.Win.UltraWinGrid.
ultraGridColumn13.AutoEdit =
false;
ultraGridColumn13.AutoSizeEdit = Infragistics.Win.
DefaultableBoolean.False;
ultraGridColumn13.ButtonDisplayStyle = Infragistics.Win.UltraWinGrid.
ButtonDisplayStyle.Always;
ultraGridColumn13.CellClickAction = Infragistics.Win.UltraWinGrid.CellClickAction.Edit;
ultraGridColumn13.CellDisplayStyle = Infragistics.Win.UltraWinGrid.
CellDisplayStyle.PlainText;
ultraGridColumn13.CellMultiLine = Infragistics.Win.
DefaultableBoolean.True;
ultraGridColumn13.CharacterCasing = System.Windows.Forms.
CharacterCasing.Upper;
ultraGridColumn13.Header.Caption =
"Catalog Desc.";
ultraGridColumn13.Header.VisiblePosition = 24;
ultraGridColumn13.MaxLength = 255;
ultraGridColumn13.SpellChecker =
this.ultraSpellChecker1;
