How do you prevent text editing in a dropdown cell? I only want the dropdown values to be selectable, no editing.
Can't help on that. I always load the cbo from a datasource without binding so it's easy in that case.
My dropdown list is bound to a subsonic active record collection from the database. How would I add a blank line? I want to do this in case the user has no selection for that field -- no selection should be a valid entry in this case.
If you set the option to drop down make sure you you add a blank line to the top or bottom of the list. Once the cbo receives focus you can't leave without making a selection. The blank line will make it where you can just tab through if you need to.
ok thanks to archive forum, you have to set column style to dropdownlist.
