1745
Problem with tabs on an unpinned dock area
I have 2 dockable panes in a dock area that is docked at the left of my window.
When pinned they display correctly as 2 tabs at the bottom of the dock area window.
When unpinned however I see only one (vertical) tab with text, together with a faint outline of a second very small tab with no text on it. If I hover over this small tab the actual tab appears and the original one now displays as a small tab with no text.
It kind of looks like it is working as a horizontal Outlook style group rather than as tabs.
See the attached screen shot.
The red box with the X is where the second tab should be - and it should say 'Favorites'.
Mike
  • 5118
    Verified Answer
    Hi Mike,
    The picture did not come through in the upload but from the description it sounds like you want to set the UltraDockManager.CompressUnpinnedTabs property to False.
    If not, try uploading the screenshot again or a small sample that demonstrates the issue.
