I'm maintaining some previously written code and have this to work with inside my Export Sub:
Dim exporter As New Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter exporter.Export(grid, filename)
Naturally, this is exporting the entire grid to the file instead of just the selected rows. I found some examples from this forum on how to add a certain handler (RowsExporting?), but when I add the handler Sub it doesn't seem to be called when the exporter.Export() is called. Am I missing a step somewhere? Thanks for any help you can provide!
I am glad to hear that you were able to achieve what you wanted. Also, please do not hesitate to contact us again, regarding any questions that you have.
Thanks, with this sample and further research I was able to get it to do what I want.
Hello kylemilner,
I prepared a sample for you and attached it to this post. You could review it and if it is not enough for you, please attach a sample of your own for me and I will be glad to take a look at it. You could do this by clicking on the 'Options' tab above and attach your file through 'Add/Update'.
