1339
UltraNumericEditor Spin Handles Max Value, But Not Min Value
Created a new form, placed an UltraNumericEditor.  Set the following values in the designer:
MaskInput = "-{double:3.2}";
MaxValue = 999.99D;
MinValue = -999.99D;
NumericType = Infragistics.Win.UltraWinEditors.NumericType.Double;
SpinButtonDisplayStyle = Infragistics.Win.ButtonDisplayStyle.Always;
SpinIncrement = 0.1D;
If I input 999.99 (max value), then use the spin button to decrement by a tenth I properly get 999.89.  Clicking to increment once puts me back at 999.99.  If I input 999.90 and increment once I get 999.99 (again, as expected).
Now input -999.99.  Incrementing with the spin button should give me -999.89, however it results in -999.00.  Attempting to decrement from here results in no change, -999.00 is incorrectly being enforced as the min value.  If I start at -999.88 and decement once I correctly get -999.98.  However decrementing from here I then get -999.00.
Latest service release of 11.1.
example.zip
  • 53790
    Verified Answer
    Hello Rastedt,
    Thanks for attached sample. I saw  your issue. As far as I know the mentioned behavior is expected. One possible way to achieve what you are looking for is to set your property MaskInput  = “{double:-4.2}”.  Please take a look at the modifications that I made in your sample and test the new behavior. If you have any questions, do not hesitate to write me
    Regards
    example2.zip
