Hi Guys,
Can you please help me to remove the indentation of groupby, while doing the export to excel.
my Group by label value is bit bigger, so in the excel sheet is looking very bad, moreover i need to scroll to see the actual data.
Is there any way to remove or minimize the indentation space taken by the GroupBy band in the Excel.
With Thanks & Regards
Amjath
This is solved now.
In some other post, mike suggest to change the layout band indentation in begin_export.
Thanks MIKE.
I did the same and this Issue get solved.
