425
How do you set DefaultValueAttribute values for WinGrid design-time serialization?
I have the UltraGrid sub-classed and will be using this class to instantiate 100+ grids in the app. Absolute property values that can not change are being set in OnEndInit and all is well here. However, I need to be able to set default property values of the grid that will be used when the grid is dropped onto a form. For example, the "this.DisplayLayout.Override.HeaderAppearance.TextHAlign" property needs to be set to the same value, say "Infragistics.Win.HAlign.Right", every time it is added to a form. Is the DefaultValueAttribute the only way to accomplish this? If so, then how? Is there an alternative? An archived forum somewhat addresses this: Subclassing Question. Thanks.
