Hi, We are trying to create a scatter chart with string labels on the X axis using the IRenderLabel concept as shown in attached screen shot. It works fine but we would like only one instance of the label to show up instead of 4 different instances and all the four data values should get plotted in a straight Y-axis line using only one X-axis label. Is this possible?
Zongwen
Hello Zongwen,
Maybe one possible approach to achieve desitred behavior could be if you are using FillSceneGraph event. I have similar sample and with small modifications you could achieve desired behavior. Please take a look at the attached sample for more details ( I made this small modifications for the first few months) and let me know if you have any questions,
Regards
does anybody know whether it's even possible or not? thank.
