I wonder how to implement in the WinGrid the column selection.
When a grid has a lot of columns, some columns should be hidded others, displayed, as user desires, like in the Windows Explorer in Details mode:
Thanks Mike Saltzman. This is exactly what I wanted.
Ah, okay, you wrote "File" instead of "Field".
Anyway, you can change the text like so:
private void ultraGrid1_BeforeColumnChooserDisplayed(object sender, BeforeColumnChooserDisplayedEventArgs e) { e.Dialog.Text = "My text"; }
as I said before
the "Field Chooser" is the header string of the field chooser control.
Field chosser appears when I click on the grid button that selects what columns will be displayed and what not.
serhiol said:this is good. How about translating "File Chooser"?
I don't understand your question. Where is "File Chooser?"
To translate any of the strings in NetAdvantage for WinForms, you use the ResourceCustomizer.
Customizing Assembly Resource Strings
