For my requirement, i have to export multiple dataset to excel and create multiple sheets. Based on my data i have to create dropdown and populate the cell. For this requirement instead of direct export using excelexport dll, i have created worksheet and updated the value.
My dataset contains several html data (eg:<b><u>Test1<u> Test2</b>). If i place the data inside excell cell, it displaying with node like <b><u>Test1<u> Test2</b>, but i want to display it as formatted text as html(eg: Test1 Test2).
To reproduce this, i will paste here sample code
Infragistics.Excel.Workbook wBook = new Workbook(WorkbookFormat.Excel2007,WorkbookPaletteMode.StandardPalette);
Infragistics.Excel.
Worksheet wSheet = wBook.Worksheets.Add("Export");
wSheet.Rows[2].Cells[2].Value =
"<b><u>Test1</u> Test2</b>";
wBook.Save(@"E:\\Test.xlsx");
It is the urgent requirement for me, any solution for this issue.
Micky
Assign a FormattedString to the Value property. The FormattedString class exposes a GetFont method which has integer parameters which represent the character positions to which those font attributes are to be applied.
