265
Header Checkbox - Enable Tristate?
I have a simple ultragrid bound to a database that countains bit (boolean) columns.
It is a requirement to be able to update all of the values in a row at once from the header, which can be achieved using the Column CheckBox properties:
col.Header.CheckBoxAlignment = HeaderCheckBoxAlignment.Right;
col.Header.CheckBoxSynchronization = RowsCollection;
col.Header.CheckBoxVisibility =
HeaderCheckBoxVisibility.WhenUsingCheckEditor;
I also have the need to be able to set the values to True, False or Null, which can also be achieved using the property:
col.Style = Infragistics.Win.UltraWinGrid.
ColumnStyle.TriStateCheckBox;
My problem is, that the CheckBoxHeader only allows the user to do a bulk update on the values to either True or False.. (not null)
Is there a way to tell the header checkbox that it is also TriState?
I can't seem to find the property anywhere to do this.
Thanks in advance,
Craig
