Is it possible to get standard PropertyGrid's behaviour with any of the components in the suite?
Thanks in advance!
Jean Paul Mir V.
The best way to emulate PropertyGrid behavior is to use the .NET PropertyGrid control. If there is some reason why you want to use our controls, please repost with details and we can try to help.
Yes,
I want to use a propertygrid on a form at runtime. I use Netadvantage in my laptop so I have not installed IIS and the Netadvantage SDK installer throw exception when it's not installed.
I'll try this example...Thanks
Hi Jean Paul,
Could you be a little more specific? What behavior are you referring to?
Do you mean you want a property grid in your application at run-time? I think there is a sample of doing this using the UltraWinTree control.
