Hello everyone,
I have searched for this and I'm sure the answer is out there but I haven't been able to find it. I want to be able to edit the first cell in every column within a band.
I tried a few things like cell activation and also setting the datacolumn to ReadOnly = false;
Neither of these things work. Any help is much appreciated. Thank you!
There's a similar question answered here:
Activation property for rows, columns and cells - NetAdvantage for Windows Forms - WinGrid
I am unable to edit a cell after locking the row.
this is to lock entire row
Me.ultraGrid1.Rows(10).Activation = Activation.NoEdit
and i need to unlock only one cell
Me.ultraGrid1. Rows(10).Cells("Select”).Activation = Activation.NoEdit
but unable to edit the select column which style is check box.
please help to lock entrie row but allow check box column to edit.
Hello Rich,
RichSee said:I guess my last question is about alternative help. Is there any kind of video tutorials or one on one sessions that can help me work with the grid designer?
I create a case for you with reference number CAS-75907-ZWZYD7. I`ll send you through the case video file which showing how to use the UltraGird`s designer. Meanwhile I include in this forum thread few links from our online documentation about the designer.
- http://help.infragistics.com/Help/NetAdvantage/WinForms/2011.1/CLR2.0/html/WinGrid_Using_the_WinGrid_Designer.html
- http://help.infragistics.com/Help/NetAdvantage/WinForms/2011.1/CLR2.0/html/WinGrid_Defining_Layouts.html
- http://help.infragistics.com/Help/NetAdvantage/WinForms/2011.1/CLR2.0/html/WinGrid_Using_the_Row_Layouts_Designer.html
- http://help.infragistics.com/Help/NetAdvantage/WinForms/2011.1/CLR2.0/html/WinGrid_Advanced_Row_Layouts_Part_1_of_2.html
- http://help.infragistics.com/Help/NetAdvantage/WinForms/2011.1/CLR2.0/html/WinGrid_Advanced_Row_Layouts_Part_2_of_2.html
- http://help.infragistics.com/Help/NetAdvantage/WinForms/2011.1/CLR2.0/html/WinGrid_Work_with_Row_Layouts.html
- http://help.infragistics.com/Help/NetAdvantage/WinForms/2011.1/CLR2.0/html/WinGrid_Grouping_Columns_in_Row_Layout_Mode_using_the_Designer.html
Please if you have any questions, do not hesitate to write me here or through the case.
Regards
RichSee said:My second thought was that Im using the Creation Filter. Do you think this could possibly be any kind of a problem by it not allowing me to edit a cell. As far as I know this code cycles through all the elements in the grid and does things as you need them to. I compared lines in the designer code with my hand code and I couldnt see anything different that we didnt try to enable the cell editing.
It depends on what your CreationFilter is doing. If you are preventing the cell from creating it's editor UIElements (perhaps because you replacing those elements with your own elements) then that could stop the cell from entering edit mode. But this is very simple to test. Comments out the CreationFilter and see if the problem still occurs.
I'm not aware of any, but I will forward this over to Infragistics Developer Support and see if they can help you there.
Hi Mike,
So I was able to come back to this code today and try out some things. I ended up making a whole new UltraGrid in the designer. When I had just the minimal things in the grid I was able to go and edit the cells. I proceeded to copy over as much code as possible and when I ran im still getting a run time error about the band not having all the columns I thought I added to it through the designer. These were the kind of problems I had at first that made me end up hand coding the whole grid.
