I get an error when performing the following.
Me.UltraChart1.SaveTo(SaveFileDialog1.FileName, System.Drawing.Imaging.ImageFormat.Wmf)
"System.ArgumentNullException: Value cannot be null"
Other format types works fine. see code below.
If SaveFileDialog1.ShowDialog() = DialogResult.OK Then Dim sExt As String = SaveFileDialog1.FileName.Substring(SaveFileDialog1.FileName.LastIndexOf(".") + 1, 3).ToUpper()
Select Case sExt Case "JPG" Me.UltraChart1.SaveTo(SaveFileDialog1.FileName, System.Drawing.Imaging.ImageFormat.Jpeg)
Case "BMP" Me.UltraChart1.SaveTo(SaveFileDialog1.FileName, System.Drawing.Imaging.ImageFormat.Bmp)
Case "GIF" Me.UltraChart1.SaveTo(SaveFileDialog1.FileName, System.Drawing.Imaging.ImageFormat.Gif)
Case "WMF" Me.UltraChart1.SaveTo(SaveFileDialog1.FileName, System.Drawing.Imaging.ImageFormat.Wmf)
End Select
MsgBox("Save As Complete", MsgBoxStyle.OkOnly, cMANAGES)
End If
Thank you
Hello Patknoll,
It is know issue for us and we work on it. I already create a case for you with reference number CAS-72070-93RGTM. I`ll provide you more information via the case. Please if you have any questions, do not hesitate to write me in this forum thread or through the case.
Regards
