350
Cell Focus
I have wingrid of two rows and two columns( i st column as like label 2nd column like text box )
i want always set the focus to cells of column 2 only
even when user select column 1 cell i want it to focus column 2 cell only
hw n where i hv to code
  • 469350
    Disabling column 0 and enabling column 1 is pretty easy. Here's a KB article that will show you how:
    HOWTO:How can I make a grid or a column, row, or cell in the UltraWinGrid disabled or read-only?
    You will probably also want to set the TabStop property on Column 0 to false, so that the tab key skips over that column.
    To make it so that clicking on the first column actually activates the second column and puts it into edit mode is a tiny bit trickier. For that, you will have to write a little bit of code.
    There are a number of approaches you could take, but here's some sample code that works well for me:
            private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e)
                UltraGridLayout layout = e.Layout;
                UltraGridBand band = layout.Bands[0];
                band.Columns["Column 0"].CellActivation = Activation.NoEdit;
                band.Columns["Column 0"].TabStop = false;
            private void ultraGrid1_AfterCellActivate(object sender, EventArgs e)
                UltraGrid grid = (UltraGrid)sender;
                UltraGridCell activeCell = grid.ActiveCell;
                if (grid.ActiveCell != null &&
                    grid.ActiveCell.Column.Key == "Column 0")
                    grid.PerformAction(UltraGridAction.NextCellByTab);
