Hi all,
I have a question regarding the FlowLayoutManager.
I added the manager to my form and set its ContainerControl to an UltraPanel.ClientArea
In the panel there are 3 usercontrols. Now I show/hide some of them and expected that the lowest control would "move up" if the middle control becomes hidden (I also tried to remove the control from the panel, same result) but the space the middle control used is still there -> a gap remains.
Is this the rigt behavior? Or am I missing something?
I also experienced problems setting the ContainerControl to the UltraPanel.ClientArea via designer.It just won't keep the selected value, only after removing the manager and readding it its value was kept (actually I had the ClientControl set to a groupbox before).
Any help is kindly appreciated,best regardsAndy
After rebooting my machine the problem magically disappeared...Everything now works as expected.
