I have the following statement in a for loop in my code to update a row in the grid.
grdRow.Cells.Item(pAttr.ColumnName).SetValue(pAttr.Value, True)
Where grdRow is Infragistics.Win.UltraWinGrid.UltraGridRow
It perfectly updates the specified row in the grid. But for every iteration the focus moves cell by cell. So at the end of the loop my grid will be focusing the last column (or last cell of the updated row). So the scroll bar moves horizontally to the end focusing the last column.
Yeah that worked if I change my argument to False instead of True. Thanks!!
I don't think this code should be changing the ActiveCell in the grid... unless maybe it's because you are passing in True for the secod parameter. This probably simulates editing a cell as though it was done by the user. If you don't want the grid to scroll, I'd recommend passing in False.
You can scroll the grid in a number of ways. Setting the ActiveRow or ActiveCell will scroll that row/cell into view. You can also use grid.ActiveRowScrollRegion methods like ScrollRowIntoView or the FirstRow property.
