I have a wingrid that I use a UltraDropDown editor for the cell input. I am getting a error from the control when I try to leave the form _ effectively forcing a loss of focus on the grid and therefore the editor control. I am unable to debug this because the error appears to be happening within the control. Error information:
{"Object reference not set to an instance of an object."}
[System.NullReferenceException]: {"Object reference not set to an instance of an object."}
Data: {System.Collections.ListDictionaryInternal}
HelpLink: null
InnerException: null
Message: "Object reference not set to an instance of an object."
Source: "Infragistics2.Win.v7.1"
StackTrace: at Infragistics.Win.Utilities.IsActiveControlHelper(Control control, IContainerControl container)at Infragistics.Win.Utilities.IsActiveControl(Control control)at Infragistics.Win.Utilities.SetFocusToOwnerIfActive(Control ownerControl, Control childControl)at Infragistics.Win.EditorWithText.OnBeforeExitEditMode(Boolean& cancel, Boolean forceExit, Boolean applyChanges)at Infragistics.Win.EditorWithCombo.OnBeforeExitEditMode(Boolean& cancel, Boolean forceExit, Boolean applyChanges)at Infragistics.Win.EmbeddableEditorBase.ExitEditMode(Boolean forceExit, Boolean applyChanges)at Infragistics.Win.UltraWinGrid.UltraGridCell.ExitEditMode(Boolean cancellingEditOperation, Boolean forceExit)at Infragistics.Win.UltraWinGrid.UltraGridCell.ExitEditMode()at Infragistics.Win.UltraWinGrid.UltraGrid.InternalLostFocus(Boolean scrolling)at Infragistics.Win.UltraWinGrid.UltraGrid.OnLeave(EventArgs e)at System.Windows.Forms.Control.NotifyLeave()at System.Windows.Forms.ContainerControl.UpdateFocusedControl()
TargetSite: {Boolean IsActiveControlHelper(System.Windows.Forms.Control, System.Windows.Forms.IContainerControl)}
I was able to finally fix this. Before leaving the grid and clearing the control I call a PerformAction(UltraGridAction.ExitEditMode) which forces my logic to run first.
Thanks for the quick response!
Make sure you have the latest Hot Fix. If that doesn't help, you should Submit an incident to Infragistics Developer Support
