880
Is it possible to only show the Row Selector once when you have multiple Column Scroll Regions?
I have a grid with two column scroll regions and Row Selectors enabled. However, I only want the Row Selectors to appear in the first scroll region (this would also ensure that he column chooser icon was only displayed once).
I've tried turning off Row Selectors using the following code but it removes them for the whole grid:
MyGrid.DisplayLayout.ColScrollRegions(1).Layout.Override.RowSelectors = DefaultableBoolean.False
Is there any way of removing the Row Selectors for a single Column Scroll Region?
I've also had some strange behaviour with fixed columns since adding a 2nd column scroll region. I have the first few columns in the grid set to fixed in the designer (with the push pin icon shown in the column header).
At run-time with 2 column scroll regions none of the columns are fixed (including the row selectors) and the push pin icons are not shown. If I manually close the scroll region and then create it again then all of a sudden the columns are now fixed and the push pins are shown.
I'm creating the 2nd column scrolling region in the designer if that helps.
John.
