Hiii,
i have created one email interface, in this interface i have used one Ultracomboeditor for add recipients. i have also set AutoCompleteMode to Suggest and DropdownButtonDisplayStyle to never. when i start to write in comboeditor it have been suggest email id to me. Everything is fine. Now user enter multiple recipients ids using comma seprator at that time how can i popup dropdown ? In OutlookExpress2010 user can easily add multiple recipients using comma. Is it possible using UltraComboEditor ?
-- Hiren Lad
Hi Hiren,
I do not beleive this is currently possible. You should Submit a feature request to Infragistics
Hello Mike,
Thanks for your reply,
I had tried to open dropdown list when user press comma in comboeditor using DropDown() method. But as you u told me AutoComplete Functionality not worked propely.. Yes you are right it's treat the value of the control as one value.... :(
Now My application wants suggest multiple email id in one textbox. like outlook express. Is it possible... ?
If you have any idea about to achive this issue, then please Explain me how ???
You can drop down the UltraComboEditor in code by calling the DropDown method on the control.
But the built-in AutoComplete functionality will not be able to function with a comma-delimited list. It treats the value of the control as one value.
