1650
Selected Column Appearance
Is it possible to control the selected column appearance?
I have ValueBasedAppearances applied through out my grid, however when I set a column to selected I loose the ability to see those colors.
Can I change the behavior of the selected column to just set a border around the column?
  • 469350
    Verified Answer
    Yes. Assuming you have a fairly recent version of the grid, you can so this:
            private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e)
                UltraGridLayout layout = e.Layout;
                layout.SelectionOverlayColor = Color.Transparent;
    If you choose a solid color, instead of Transparent, then the selection will display as a semi-transparent overlay - so you will still be able to see the appearance of the cells underneath it.
    You may also want to set SelectionOverlayBorderThickness and SelectionOverlayBorderColor.
