Hi Team,
I would like to know if there is any property which will resize the grid on maximize and on restore down it will autofit to the winform available.
As of now the grid remains the same and therefore it hides the few columns on restore down. Please advice.
Ya got the solution.. thanx :)
HI dineshjain,
It has been some time since you posted this so I am not sure if you have already got your answer but here is what I recently found out.
In the UltraWinGrid Designer under Feature Picker, expand AutoFit Style. Select Resize All Columns.
If you set the column widths in InitializeLayout, the proportions will stay the same when maximized.
Let me know if this helps you or not.
please ignore this post, it got duplicated. If moderators can delete , please do it.
