When I shift the icon to the left more, there is a space shown as below.How to make it invisible??
Hello Rchiu5hk,
If I understand well your scenario and looking on the screenshot, your image contain the text Receive Products. Is it correct ? If so, you could change property “Style of Group = small images” or “Style of Group = large images”. By this way the control will shows only the image and will be fit in all available space.
Please let me know if you think that I misunderstand your scenario or if you have any questions.
Regards
This is because my icon width does not fit with the ultra explorer bar item, when selecting, I think the empty text behind is bordered. Is there any method??
For me is difficult to guess only from the screenshot what is wrong. Did you try to change the margins and spacing of your Around Items (outer) and Around Items (inner) margins. You could change these properties via UltraExplorerBar designer -> Tab Margines and Spacing. Are you loading any layout from file ? Could you please send me small sample that reproduce your issue. I`ll be glad to research it for you
