410
How Do I specify individual columns for Export?
I'm using the UltraGridExcelExporter to export contents from a DataGridView.  The DataGridView has many columns and I only want certain columns to be exported, for instance "reading_date", "gw_elev_ft" and "gw_depth_ft"
How can I specify this using my existing block of code?:
private void ExportGraphingDataToExcel()
      string sensorName = cbxMonitorList.Value.ToString();
      string startDate = clndrGwMonStart.Value.ToString("yyyyMMdd");
      string endDate = clndrGwMonEnd.Value.ToString("yyyyMMdd");
      string graphingDataExportFilePath = "C:\\temp\\GraphingData" + "_" + sensorName + "_" +   startDate + "-" + endDate + ".xls";
      try
        SetStatus("Exporting monitor graphing data to Excel file...");
        this.ultraGridExcelExporter.Export(this.dgvGwMonGraphData, graphingDataExportFilePath);
        MessageBox.Show("Groundwater monitor graphing data exported to " + graphingDataExportFilePath, "Export Complete", MessageBoxButtons.OK, MessageBoxIcon.Information);
      catch (Exception ex)
        SetStatus("Error encountered...");
        MessageBox.Show("Error running ExportUpdateErrorsToExcel: " + ex.Message, "Export Error", MessageBoxButtons.OK, MessageBoxIcon.Error);
        finally
        SetStatus("Ready");
  • 410
    Verified Answer
    posted in reply to Mike Saltzman
    Yes you are correct. I simply renamed the UltraGrid and refer to them as "dgv___"
    I used the following code from here: http://sblanco.wordpress.com/category/infragistics-winforms/
    and your code to get the following:
    using Infragistics.Win.UltraWinGrid.ExcelExport;
    ultraGridExcelExporter.BeginExport += delegate(object sender, BeginExportEventArgs e)
              ColumnsCollection columns = e.Layout.Bands[0].Columns;
              columns.Band.Columns["gwmon_edit_id"].Hidden = true;
              columns.Band.Columns["session_edit_id"].Hidden = true;
              columns.Band.Columns["edit_date"].Hidden = true;
              columns.Band.Columns["edited_by"].Hidden = true;
              columns.Band.Columns["sensor_name"].Hidden = true;
              columns.Band.Columns["reading_hertz"].Hidden = true;
              columns.Band.Columns["head_ft"].Hidden = true;
              columns.Band.Columns["head_psi"].Hidden = true;
              columns.Band.Columns["f2_scale"].Hidden = true;
              columns.Band.Columns["ground_elev_ft"].Hidden = true;
              columns.Band.Columns["max_gw_elev_ft"].Hidden = true;
              columns.Band.Columns["min_gw_elev_ft"].Hidden = true;
    WORKS PERFECTLY. Thanks a lot!
  • 469350
    Verified Answer
    I'm a bit confused. The UltraGridExcelExporter only works with the UltraGrid control. It does not work with a DataGridView. So I can only assume that this.dgvGwMonGraphData is an UltraWinGrid and not a DataGridView. Otherwise, this code would not even compile.
    Anyway, what you can do is handle the BeginExport event of the UltraGridExcelExporter. This event passes you a Layout which is a clone of the on-screen grid's layout. Since it's a clone, you can modify the layout and it will affect the export and not the on-screen grid. So you can simply hide the columns you want to hide:
    e.Layout.Bands[0].Columns["my column"].Hidden = true;
