I have a WinGrid with an unbound column with Style Checkbox; I would like it to be initially checked. I have set the DataType to System.Boolean, and the DefaultCellValue to true, but the checkboxes are all unchecked when the grid is made. How can I get it to show the checks?
In addition, how can I set the checkbox checked state programatically in general? It seems to be difficult... Thanks!
Hello Joels,
Maybe one possible approach to achieve desire behavior is to use the code below:
private void ultraGrid1_InitializeRow(object sender, Infragistics.Win.UltraWinGrid.InitializeRowEventArgs e){ if (!e.ReInitialize) { e.Row.Cells["Column key"].Value = true; }}
Please if you have any questions, do not hesitate to ask meRegards
