110
Text not selected on TAB enter
 When navigating fields in an application using tab all decimall fields with data select all the data.
However(and this is only on a single PC it works on all others) when tabbing into a text box that has data the cursor defaults in front of the current text instead of selecting it all to overwrite when typing.
I am wondering what would cause this to happen only on a single client and work on all others?
  • 110
    Verified Answer
     I found out that this is not an infragistics issue but rather a keyboard issue and the enter event for the textbox.  After swapping out a dell keyboard for another brand the SelectAll worked as is should.
    Strange.
