70
UltraWinGrid Mask Input Cell
Is it possible to set an input mask on a column on a row-by-row basis, depending on the contents of a cell in that row?
I have an UltraWinGrid that is being bound to a DataSet generated dynamically at runtime.
There is a column in my Grid that is giving me an "ID Number" as an Integer.  A separate column defines the "ID Number" as an EIN or an SSN.
If the "ID Number" is EIN I want the mask to be ##-#######.  If it is SSN it should be ###-##-####.  Is this a possibility?
Thanks for your consideration.  I hope I haven't repeated a topic from elsewhere.
VB.NET 2008 and Infragistics 9.1
  • 469350
    Verified Answer
    Yes, this can be done by applying a different editor to each cell and telling the column to use the editor mask settings instead of it's own settings.
    I have attached a small sample project here demonstrating this technique. Here's what the relevant code looks like:
            private void Form1_Load(object sender, EventArgs e)
                this.ultraMaskedEdit1.InputMask = "##-#######";
                this.ultraMaskedEdit2.InputMask = "###-##-####";
            private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e)
                UltraGridLayout layout = e.Layout;
                UltraGridBand band = layout.Bands[0];
                band.Columns["ID Number"].UseEditorMaskSettings = true;
                band.Columns["ID Number"].MaskDisplayMode = Infragistics.Win.UltraWinMaskedEdit.MaskMode.IncludeBoth;
            private void ultraGrid1_InitializeRow(object sender, Infragistics.Win.UltraWinGrid.InitializeRowEventArgs e)
                this.UpdateIDEditor(e.Row);
            private void UpdateIDEditor(UltraGridRow row)
                bool IdType = (bool)row.Cells["ID Type"].Value;
                this.UpdateIDEditor(row, IdType);
            private void UpdateIDEditor(UltraGridRow row, bool IdType)
                if (true == IdType)
                    row.Cells["ID Number"].EditorComponent = this.ultraMaskedEdit1;
                else
                    row.Cells["ID Number"].EditorComponent = this.ultraMaskedEdit2;
            private void ultraGrid1_CellChange(object sender, CellEventArgs e)
                if (e.Cell.Column.Key == "ID Type")
                    // The Value of the cell will not be updated at this point, so we
                    // must use the Text.
                    bool value = bool.Parse(e.Cell.Text);
                    this.UpdateIDEditor(e.Cell.Row, value);
    WindowsFormsApplication19.zip
