920
HotTrackedCellAppearance and ActiveRowApearance
Hello.
I've an UltraGrid which I specify a BackColor for each cell, and it changes depending some things of the system. So, I've set in my isl file for the UltraGridRow and UltraGridCell in the states: normal, active, selected and hottracked the backcolor as transparent.
I'm having two problem:
     When I click some cell all the cells in the row changes its BackColor to white. I've "solved" adding this code to the end of CellClick event:
foreach (UltraGridCell cell in e.Cell.Row.Cells)
    cell.ActiveAppearance = cell.Appearance;
    cell.SelectedAppearance = cell.Appearance;
but it makes a blinking between white BackColor and the right one.
     My second problem: on the mouse over event of a cell it puts its BackColor as white, no motter I've set UltraGridCell -> HotTracked -> BackColor as white.
Thanks for the help.
Diego
