35
When I use the instance WindGridExcelExport then canceled for error: Message=Parameter is not valid
Hi, My Name is Edmundo Guerrero
I am working with the following tools:
  • 1. Windows XP SP3
  • 2. Microsoft Visual Studio 2010
  • 3. Version 10.0.30319.1 RTMRel
  • 4. Installed Version: Premium
  • 5. Microsoft .NET Framework
  • 6. Version 4.0.30319 RTMRel
  • 7. Using Vb.Net
  • 8. NetAdvantage 11.1 Win CLR 2x
  • 9. Reference Named:
  • 10. infragistics2.documents.excel.v11.1
  • 11. infragistics2.win.ultrawingrid.excelexport.v11.1
  • 12. Application Styling Configuration Dialog
  • 13. The program is compiled and shows 0 errors, 0 warnings and 0 messages
The Problem.
When I instantiate the UltraWingGrid.ExcelExport as shown below:
 If e.Tool.Key = "Exportar a Excel" Then
            Dim HojaExcel As New UltraGridExcelExporter
            HojaExcel.Export(Me.UltraGrid1, "c:\pais.xls")
            Process.Start("c:\pais.xls")
        End If
and run the program the following errors message displayed:
System.ArgumentException was unhandled by user code
  Message=Parameter is not valid.
  Source=System.Drawing
  StackTrace:
       at System.Drawing.Graphics.GetHdc()
       at Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter..ctor()
       at MenuPrincipal.pais.UltraToolbarsManager1_ToolClick1(Object sender, ToolClickEventArgs e) in E:\Sistema Minerva2010\MP\MP100\MenuPrincipal\pais.vb:line 281
       at Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.OnToolClick(ToolClickEventArgs e)
       at Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.FireEvent(ToolbarEventIds id, EventArgs e)
       at Infragistics.Win.UltraWinToolbars.ToolBase.OnToolClick()
       at Infragistics.Win.UltraWinToolbars.ButtonToolUIElement.DoClickProcessing(MouseEventArgs e)
       at Infragistics.Win.UltraWinToolbars.ButtonToolUIElement.OnMouseUp(MouseEventArgs e)
       at Infragistics.Win.ControlUIElementBase.ProcessMouseUpHelper(Object sender, MouseEventArgs e)
       at Infragistics.Win.ControlUIElementBase.ProcessMouseUp(Object sender, MouseEventArgs e)
       at Infragistics.Win.Utilities.ProcessEvent(Control control, ProcessEvent eventToProcess, EventArgs e)
       at Infragistics.Win.UltraControlBase.OnMouseUp(MouseEventArgs e)
       at Infragistics.Win.UltraWinToolbars.UltraToolbarsDockArea.OnMouseUp(MouseEventArgs e)
       at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
       at System.Windows.Forms.Control.WndProc(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
       at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
  InnerException:
Thank you very much in advance for a quick response.
Edmundo Guerrero
