350
How to set series from code
I'm doing a simple query that for each security principal (A), n values ​​are recovered side. (A1, A2, A3 .... An)
This data comes from a dataset (a query from database)
By assigning the data from the dataset to the DataSource control displays all the data without performing a series grouping.
How I can from code by performing grouping sets for my data? thanks
  • 26458
    Are you using a column chart?
    Are there multiple rows in your data and more than two columns?
    The default behavior of the column chart is to group all column values within a single row together. Each row will be a separate group.
    Make sure your dataset looks something like:
               column1 , column2 , column3
    row1        A1             A2              A3
    row2       B1             B2              B3
    row3       C1            C2              C3
