450
Can I get WinTree to honour ShowLines in OutlookExpress style?
I need to use an Outlook Express style for my data as all children share common properties and so I only want to show a single column header. However when I set the WinTree to OutlookExpress style I loose the lines connecting the nodes and the images I had assigned.
Is there any way to get the lines and the images to display when in OutlookExpress style or is the are alternate way of doing this with a WinGrid?
Murray
  • 69832
    Node connector lines cannot be supported in OutlookExpress style because since the expansion indicators appear inside the cells, the connector lines would have to intersect with the cells, drawing over the cell area.
