1405
AppStylistRuntime has no ComponentRole Tooltips?
I haven't looked into this in depth, I thought maybe somebody has run into this already and may have a quick answer for me.
My setup is basic, I just started a new solution, added a form with a WinFormManager and dropped a AppStylistRuntime onto it. I added an .isl file into my project and set its build action to embedded resource.
In the constructor of my form I load the .isl as follows:
using (Stream stream = Assembly.GetExecutingAssembly().GetManifestResourceStream("LSLSchedule.LSLScheduleStyle.isl"))
                    StyleManager.Load(stream);
Followed by:
 this.appStylistRuntime1.ShowRuntimeApplicationStylingEditor(this, this.Text);
The behaviour I'm seeing is that the app stylist does show, the control to select style sets and component roles but however I cannot not hover over components to get a tooltip and modify the L&F from there.
Any ideas?
  • 1405
    Verified Answer
    Ah, nevermind. The answer is simple.
    I attempted to set the StyleLibraryName in the appStylistRuntime properties. Removing this fixed the issue.
    Cheers.
