245
DataBinding & UltraTimeSpanEditor
I am trying to bind an UltraTimeSpanEditor to a Time field in an SQL Server 2008 database.
However, when I try and update the value (1 day)  from the control to the database I get the following error:
"SqlDbType.Time overflow.  Value '1.00:00:00' is out of range.  Must be between 00:00:00.0000000 and 23:59:59.9999999."
Is it not possible to bind the control like this? Otherwise is there some other SQL Server field that i can bind to?
Thanks!
  • 53790
    In your issue you need to map Microsoft SQL Server 2008 data type Time(7) or TimeSpan:time(7) and  .NET Framework 3.5 SP1 System.TimeSpan. However, there is a large difference between the range that the CLR System.TimeSpan supports and what the SQL Server TIME type supports. Mapping values less than 0 or greater than 23:59:59.9999999 hours to the SQL TIME will result in overflow exceptions. For more details you could take a look at : http://msdn.microsoft.com/en-us/library/bb386947.aspx
    Our UltraTimeSpanEditor use data type TimeSpan which has one additional “place” for days - 0.00:00:00.0000000. If you want to bind the field, before storing/reading the data in the database you would need to take care for the Days “place” and store/read this additional information in/from separate a column (for example: columns Days – type int).
    Maybe one other approach is to use SQL  data type “nvarchar” . By this way you need to convert your TimeSpan  value to string and back to TimeSpan.
    Please if you have any questions do not hesitate to ask me
    Regards
