110
UltraDataSource vs BindingSource
Can you please explain the purpose of the UltraDataSource and why one would use it instead of the standard WinForms BindingSource ?
Thank you,
Craig
  • 48586
    I just wanted to know if you were able to solve your issue based on Mike's suggestions or you still need help? Just let me know.
    Thank you.
  • 469350
    Suggested Answer
    Hi Craig,
    There's really no comparison between UltraDataSource and a BindingSource. They are two completely unrelated functionalities.
    The BindingSource is simply a wrapper for some other data source, like a DataSet or a BindingList<T>, which provides some extra support for data binding.A BindingSource is useless by itself.
    If you are doing a comparison, you would compare UltraDataSource to other data sources like a DataSet, DataTable, or BindingList<T>.
    UltraDataSource is generally a bit faster than a DataSet or DataTable, since it's relationships are defined up-front. It's useful if you want to bind a grid to a fixed set of Data that you define in code, and does not come from a database.
    It also has load-on-demand functionality, so it's useful in cases where you don't want to load all of the data into memory at once.
    A DataSet, on the other hand, has lots of database-related functionality. It tracks changes for you so that you can update the back end.
