Hi,I'm just encapsulating the ultra colour picker for our app framework. I want to be able to not show the text value of the colour. So it just shows the colour block. Is there a way to do this? Or do I just need to limit the size of the control so you can't see the colour bit? (thats a bit of a nasty way to do it!)Also more importantly how do the colour names and tabs react when in difference languages? Really we only need the colour picker/custom colour tab, not the Web/System tabs, can we disable them?RegardsChris
Yeah that is what I wanted to hide. Thanks
The latest is 16.2. The new ColorPicker look and feel was added in 16.2. The new style doesn't have tabs and no longer supports System colors (which is probably the tab you are trying to hide).
What's the latest version? I'm using v16.1.
No, there's no way to hide tabs. However, the latest version of the ColorPicker no longer uses tabs at all. It's been completely re-designed.
Hi Torrey,
Can we just remove one tab keeping normal functionality of ultracolorpicker as it is??
