Dear all,
I have set the cellchange event in the ultragrid and set some checking in it and prompt the message if there is any input error. How can I make sure that there is correct input and then it is allowed to move to another cell by tab, left key or mouse click??
You can simply use grid.ActiveCell to get the cell. And, of course, the cell has a Column property.
I find that BeforeExitEditModeEventArgs which cannot locate the cell or column index.
How can I do if I want to check the column index and cell value??
I would use the BeforeExitEditMode event instead of CellChange. If your validation fails, you can set e.Cancel to true to keep the user from leaving the cell.
