165
Text in the UltraComboEditor disappeared when it lose focus
Hi, Mike
I am trying the method you proposed in the post http://community.infragistics.com/forums/p/55961/287029.aspx#287029, "hide the "real" column which contains a single string and use an unbound column whose datatype is List<string> for display to the user. You could then use events of the grid to convert the string to a list (InitializeRow) and the list to a String (BeforeRowUpdate)."
During the test, i found the text in the ultraComboEditor disappeared when the cell lose focus, the cell changed to blank. i pasted some code here,
private void ultraGrid1_InitializeLayout(object sender, IWG.InitializeLayoutEventArgs e)
// override the backgroud color of the active cell.
this.ultraGrid1.DisplayLayout.Override.ActiveRowCellAppearance.BackColor = Color.White;
this.ultraGrid1.DisplayLayout.Override.ActiveRowCellAppearance.ForeColor = Color.Black;
this.Columns[StrValue].Hidden = true;  // hide the real bound column
this.Columns.Add(m_fakeColName, "NewValue"); // add a fake column
this.Columns[m_fakeColName].DataType = typeof(List<string>);
// fill the cell with different controls based on the cell content before the active cell
private void ultraGrid1_BeforeCellActivate(object sender, IWG.CancelableCellEventArgs e)
if (e.Cell.Column.Key.Equals(m_fakeColName))
string property = e.Cell.Row.Cells[StrProperty].Value.ToString();
if (string.IsNullOrEmpty(property)) return;
if (m_propertyAttriDic[property].CtrlStyle == ControlStyle.CheckedListBox)
            Columns[m_fakeColName].Style = IWG.ColumnStyle.DropDownList;
            if (cell.EditorComponent == null)
                    UltraComboEditor editor = new UltraComboEditor();
                    editor.CheckedListSettings.CheckBoxStyle = Infragistics.Win.CheckStyle.CheckBox;
                    editor.CheckedListSettings.ItemCheckArea = Infragistics.Win.ItemCheckArea.Item;
                    editor.CheckedListSettings.EditorValueSource =                           Infragistics.Win.EditorWithComboValueSource.CheckedItems;
                    editor.CheckedListSettings.ListSeparator = new string( FilterHelper.Seperators);
                     editor.ValueList = this.ultraGrid1.DisplayLayout.ValueLists[propertyName];
                     this.Columns[m_fakeColName].EditorComponent = editor;
private void ultraGrid1_BeforeRowUpdate(object sender, Infragistics.Win.UltraWinGrid.CancelableRowEventArgs e)
List<string> values = e.Row.Cells[m_strFakeValueCol].Value as List<string>;
if (values != null)
string newValue = string.Empty;
foreach (string value in values)
newValue += value;
if (values.IndexOf(value) < values.Count - 1)
newValue += new string(FilterHelper.Seperators);
m_filterList[e.Row.Index].Value = newValue;
private void ultraGrid1_InitializeRow(object sender, Infragistics.Win.UltraWinGrid.InitializeRowEventArgs e)
string value = e.Row.Cells[StrValue].Value as string;
if (!string.IsNullOrEmpty(value))
e.Row.Cells[m_strFakeValueCol].Value = new List<string>(value.Split(FilterHelper.Seperators));
Thanks in advance.
louvie
