1145
Select All Header Checkboxes?
Version 9.2 - All 30+ column headers in our grid have header checkboxes (HeaderCheckBoxVisibility.Always).  I have been searching (for way to long) to provide a way for a user's action to programmatically select (set the CheckedState to Checked) on all columns.  The default is to have all column header checkboxes unchecked as 70% of the time the users will be selecting (checking) only a handful of columns.  So this question is for the other 30% of the time where they only want a small number of columns unchecked thus saving them some serious mouse clicking.
The trigger for this is ready, Thanks in advance!:
 private void gridBuySell_AfterHeaderCheckStateChanged(object sender, AfterHeaderCheckStateChangedEventArgs e)
switch (e.Column.GetHeaderCheckedState(e.Rows))
case CheckState.Checked:
if (e.Column.Header.Caption == "Exclude All")
foreach()
//Need to check all column header checkboxes
 c.Column.Header = CheckState.Checked;
break;
case CheckState.Indeterminate:
break;
case CheckState.Unchecked:
//Need to uncheck all column header checkboxes
break;
default:
break;
A second question is how can we post code so its format look proper in this forum?
