i am referencing the following post:
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=4791
to turn off the focus rectangle for a row when it is activate. For several rows in the grid, i have set thier back color and forecolor to different colors based on information in that row. however, now when i click on one of those rows, no focus rectangle is drawn, but the back color is made to white and forcolor is black (im guessing the default). How can i make it so the back and fore colors are retained but no focus rectangle is drawn. I am attempting to make it appear that no row is ever selected. Thanks for any replies.
-Chris
Georgi,
That worked beautifully, and no DrawFilter code required!!! That is great! Thanks for your response!
Hello Chris,
Maybe one possible approach to achieve desired behavior is by using grid property "ActiveAppearanceEnabled = DefaultableBoolean.False"
private void ultraGrid1_InitializeLayout(object sender, InitializeLayoutEventArgs e){ e.Layout.Override.ActiveAppearancesEnabled = DefaultableBoolean.False; e.Layout.Override.SelectedAppearancesEnabled = DefaultableBoolean.False;}
