Good morning,
Using version 10.2 of the wingrid object.
I want to format the cell display of col2 based on the value in col1.
So the rows in col1 can have many different values.
Col2 has numeric data in each cell.
Some of col2 data is currency values some are percentage values.
Need to format the values with the #.##% sign or the currency $##,##0.00 formats.
Can this be done? And if so can you give an code example? [ VB.net would be nice :) ]
I am currenlty looking at the InitializeRow event of the grid.
Select Case e.Row.Cells(0).Text Case "Perc %" e.Row.Cells("Zone 1 Quant").text.Format("#0.00%") Case Else e.Row.Cells("Zone 1 Quant").text.Format("$##,##0.00")End Select
Deasun
Hi Deasun,
I am attaching a little sample I whipped up a while ago that demonstrates how to do this.
Thanks, will have a look thru it.
