I have a grid with tooltips dynamically changing for different cells on the grid. I an currently assigning the tooltiptext in the below way
ugRow.Cells(VALIDATE_COLUMN).ToolTipText = '' text..."
Can i change the format of the text i.e the font, color, size of the text and set to the ToolTipText property so that the tool tip is more visible for the users?
Thanks for the idea. It works
You could do this in a couple of ways.
The first way would be to turn off the automatica tooltips in the grid and use UltraToolTipManager to show the tooltips yourself. There's a sample of this included with NetAdvantage. It's called ToolTips with Context.
The other approach would be to use a CreationFilter and modify the IToolTipInfo for the CellUIElement.
