The issue I have is that I need to format the label text to currency but using the calcmanager, it fails when the text is formated using Format(txtValue, "c"). I think that MaskEdit gets around this issue by having both a value property and a Text property. I guess I could use the Tag property as the value calculated and the text property as the format value? Not sure if this will work?
Any other ideas?
Using a MaskEdit is not an option since it needs to look like a label without appearance trickery.
Any idea how I can format the label text but still use calcmanager?
I,ll take my answer off the air...lol
Thanks, -Joe
Got it working.
Solution was to use the Tag property to calculate via the CalcManager .PropertyName = "Tag"
One other issue was the sync between Tag and Text property. For this I simply had to override the base Tag property and set the text formating accordingly. Also added an event for custom formating and call it last to give custom handlers a crack at it.
Public Class CurrencyLabel Public Delegate Sub TagChangedEventHandler(ByVal sender As Object, ByVal e As TagEventArgs) Public Event OnTagChanged As TagChangedEventHandler Public Sub New() InitializeComponent() End Sub Public Shadows Property Tag() Get Return MyBase.Tag End Get Set(ByVal value) MyBase.Tag = value MyBase.Text = Format(value, "c") Dim TE As New TagEventArgs(value) RaiseEvent OnTagChanged(Me, TE) End Set End Property Public Class TagEventArgs Inherits EventArgs Private _tag As Object Public Sub New(ByVal ptag As Object) _tag = ptag End Sub Public ReadOnly Property tag() As Object Get Return _tag End Get End Property End Class End Class
