195
Strange error with the ultraComboEditor
I have an ultraComboEditor with AutoCompleteMode=Suggest and AutoSuggestFilterMode=Contains, the ValueList is set to a value list created dynamically.  IF the control is set to the 1st tab stop and you begin typing in the combo editor, you're receive the error below.  If I change the control to the 2nd tab stop everything works as expected.  If you change AutoComplete and AutoSuggest back to default, everything works as well.  I tried recreating this in another project without success, however, in my production app it is 100% reproducible.
We're using 10.3.20103.2083
System.NullReferenceException: Object reference not set to an instance of an object.
   at Infragistics.Win.ValueList.Infragistics.Win.IFilterableValueList.ApplyFilter(Object value, AutoSuggestFilterMode filterMode)
   at Infragistics.Win.EditorWithCombo.ProcessAutoComplete(Keys lastKeyDown)
   at Infragistics.Win.EditorWithCombo.ProcessTextBoxTextChanged(Boolean& selectionChangedByAutoEdit)
   at Infragistics.Win.EditorWithCombo.Infragistics.Win.IEmbeddableTextBoxListener.OnTextChanged()
   at Infragistics.Win.EmbeddableTextBox.OnTextChanged(EventArgs e)
   at System.Windows.Forms.TextBoxBase.WmReflectCommand(Message& m)
   at System.Windows.Forms.TextBoxBase.WndProc(Message& m)
   at System.Windows.Forms.TextBox.WndProc(Message& m)
   at Infragistics.Win.EmbeddableTextBoxWithUIPermissions.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
