835
UI Help adding Rows to Bands
Below is a capture of a form in development. I need some help regarding how to handle allowing the user to add or delete rows or bands. The requirement is that the user be able to add, insert, or delete any of the grid rows or band, anywhere in the hierarchy.
For example, the user should be able to insert an Operation band between PRE-MIX #1 and PRE-MIX #2.
Any suggestions as to how to handle through UI are appreciated. The two thoughts that are currently being worked on are a context menu and a context group associated with the ribbon (not visible in the attached image).
Thanks.
