235
Data binding to a dynamic cell
I am trying to figure out a way to do the follow:
I have an UltraGrid with 1 hidden primary key column and  5 visible data columns.
Column 1 and 2 are drop down lists.
Column 3 is a dynamic cell.
Column 4 is a text field
Column 5 is a drop down list.
I have an ultra data source, a DataSet, and DataTable.  The DataTable matches the ultraDataSouce:
string, string, object, double, string. I can data bind the Columns 1, 2, 4, and 5. But column 3 is the tricky one.
When the user makes a selection on column 2, the cellListSelected event is fired, and its event handler should analyze the selection, and make column 3 a text field, edit field with an edit button, default text with an edit field and edit button, or a drop down list for other selections.
My question is, how does data binding work with such a situation? Is it even possible?
